Community Member
WAN link issue
I have 20 Mb wan link , it shows interface output like
5 minute input rate 59454000 bits/sec, 5713 packets/sec
5 minute output rate 3956000 bits/sec, 3384 packets/sec
Is it possible ?
It generate wrong reports to solarwind.
Kindly suggest.
Re: WAN link issue
whats the interface you have for the 20 Mb Wan link,
Show run and show int would be helpful.
Also let us know which option of solarwinds you are finding like gauge or bandwidth monitor.
Pravin
Community Member
Re: WAN link issue
interface FastEthernet2/0
ip address ----- -----
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
!Host#sh int fa2/0
FastEthernet2/0 is up, line protocol is up
Hardware is i82543 (Livengood), address is 0021.1e55.1238 (bia 0021.1e55.1258)
Internet address is a.b.c.d/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 19/255, rxload 32/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:06, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d06h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 12643000 bits/sec, 1792 packets/sec
5 minute output rate 7474000 bits/sec, 1542 packets/sec
235167050 packets input, 1777252135 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
44 input errors, 0 CRC, 0 frame, 0 overrun, 44 ignored
0 watchdog
152937183 packets output, 3734101951 bytes, 0 underruns
0 lost carrier, 0 no carrier
Re: WAN link issue
HI,
I am not sure about the problem.
But the outpt you have pasted isactually showing the interface utilization just for 5 minutes. It does not tells you the link badwidth.
Request give some more details about your issue.
-> Sushil
Re: WAN link issue
try this.
On this interface apply the command bandwidth with the your link speed 20Mb. this should be applied in kilobits.
The reason why it is calautaion in this way is because this is a fa link. and see the aoutput by ur self.
BW is showw as 100Mb. The bw commnad will not do any diffrence to the interface but will help it in calulating it.
Hope this helps
regards,
Pravin
Re: WAN link issue
I don't think configuring the bandwidth command is going to make any difference.
However it does not hurts to give it a try.
Would like to see the result.
-> Sushil
Community Member
Re: WAN link issue
Sushil/Pravin ,
My question is if ISP has given me 20 Mb link then how the input rate on the link is near about 59 Mb thats why in solarwind my link shows as 300% utilization.
Pravin in solarwind i have configured the bandwidth as 20000000.
I will configure the bandwidth as 20000 on both side int but i have to moniter tommorow the utilization as there are no users available now.
Re: WAN link issue
Let me explain why you are seeing the 59 Mb. As i said above the FA interface calulates the BW with defaul of 100Mb.
In case of serail E1 or T1 the clock is auto set to 2 Mb or 1.5 Mb.
Since it is a FA interface you need to use the command "Bandwidth 20000" on the interface.
If its a solarwinds gauge in setting it will take it default as 100Mb you need to change that again to get the BW of 20000.
Hope this helps
regards
pravin
Community Member
Re: WAN link issue
pravin,
Let me know solarwind takes which bw from router .
is it the input output rate ?
Re: WAN link issue
Solarwinds polls the routers information. What you can see on the router you will able to see the same on the solarwinds. It will poll the input and the output rate. Depending on the tools you are using.
For calculating purpose and see if what is been calculated on the interface is right thats the reason why i have recommeded for the commnad. If that show rx and tx as 255 and 255 that means you are getting 100 % at the same time you can check what is the reflected bw on the solarwinds. Using the Gauge is the best option.
regards,
Pravin
Community Member
Re: WAN link issue
Hi Pravin ,
I have configured the bandwidth on wan link as 20000.It is not so helpful as traffic is coming on link more than 20Mb/s , in solarwind it is showing more than 100%.
Let me know if any changes need to be done.
Find the link interface o/p
Hardware is i82543 (Livengood), address is 0021.15.18 (bia 0021.1c55.1838)
Internet address is 1.1.1.1/30
MTU 1500 bytes, BW 20000 Kbit, DLY 100 usec,
reliability 255/255, txload 18/255, rxload 148/255
Last input 00:00:05, output 00:00:00, output hang never
Last clearing of "show interface" counters 2d02h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 123
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 1/1 (allocated/max allocated)
Available Bandwidth 13744 kilobits/sec
30 second input rate 11622000 bits/sec, 1466 packets/sec
30 second output rate 1438000 bits/sec, 1081 packets/sec
293309174 packets input, 3565880068 bytes
Received 3 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
201240478 packets output, 838151282 bytes, 0 underruns
1 output errors, 0 collisions, 1 interface resets
1 lost carrier, 0 no carrier
Re: WAN link issue
As per the out i dont see its 100 %
txload 18/255, rxload 148/255. 148 would be around 60 to 70 % used.
Since you say that the solarwinds is showing you 20 Mb at point of time and the interface also might have 255/255 at a point then surely you are getting more bandwidth that what you need to.
Is this link from the ISP pluged into the fa port ?
regards
pravin
Community Member
Re: WAN link issue
Pravin ,
Output given above isnot for 100 or more %.I have given just int o/p.I am watching always the 5 min in/out avg rate.
My basic question is solarwind takes which bw it is txload18/255 , rxload148/255 or 5 minutes in/out put rate ?
My guess is it is 5 min input and output rate as i saw the same in solarwind also.
Re: WAN link issue
solarwinds has a option where in you can set the time it polls it. The Minimum is 3 sec. I would not say that it would reflect the rx/tx or 5 min output. It will poll the interface depending on the set time to poll interverl on the soalrwinds. If you set it to 3 seconds it will reflect each varations in BW in 3 sec.
The polling on solarwinds is through the SNMP if the snmp traps are right it will reflect the right BW on the monitoring tool.
Pravin
Community Member
Re: WAN link issue
Thanks prvin ,
I have the problem with receive BW which shows me more than 20 Mb how it is possible as reliance has given me link of 20 Mb only.
on int if 5 min input rate shows as 59000000 bit/sec it means 59 Mb/Sec is traffic arriving on your port , am i right ?
Re: WAN link issue
Reliance infocom. Well can you let me know which location this is for.
Reliance provides wireless LMDS service with frame-relay also. If so i can tell you where they have done a mistake.
Pravin
Community Member
Re: WAN link issue
both end of link are in pune.Reliance has given the link through fiber terminated on mux at both end.
They have the cisco switch at both end from which we get the link.
Re: WAN link issue
They uses flag as uplink. Uplink device atrica and the bw is been configured on centrel office router which is 7200 connected to a ALCATEL.
It can be possibility of config mismatch with the ISP side.
Please do check with ISP for the BW provided.
Pravin
185
