08-05-2009 12:18 AM - edited 03-04-2019 05:39 AM
1. the customer has two wan links
need:
when the traffic on link no.1 reach thershold level the traffic must go by link no.2
if it possible how can i make this configuration
08-05-2009 01:54 AM
Hi Wael,
This is possible to do using Optimized Edge Routing (its new name is Performance Routing).
Here is the link to the configuration guide:
http://www.cisco.com/en/US/docs/ios/oer/configuration/guide/12_4t/oer_12_4t_book.html
Cheers:
Istvan
08-05-2009 03:58 AM
thanks for your help but This solution need 2 routers at least one is OER master and other is OER border and i have only one router is it possible to apply oer on this router
08-05-2009 04:07 AM
Yes, it is possible to run the Master Controller and the PfR Border Router on the same router.
Istvan
08-10-2009 01:06 AM
thank you very much for your generous help
