03-10-2008 10:13 AM - edited 03-03-2019 09:03 PM
I am just a novice trying to know more about Lan/Wan,i just wanted to know in a most production enviroment what Wan technology is used
Is it frame relay, ATM or any other?
What technology should i practice most on my home lab so that i know what to say in the interview cause i dont have any experience except the CCNA certification
Can anybody give me a little update on that. I would really appreciate any help
03-10-2008 10:38 AM
LOL..Gur, I can respect your honesty...
"What technology should i practice most on my home lab so that i know what to say in the interview cause i dont have any experience except the CCNA certification..."
Anyway, ATM, Frame Relay, MPLS, MetroEthernet, etc, are all used extensively. If you really want to practice with different technologies, I suggest you configure a lab setup for each one of them one at a time...
I believe there are CCNA network Simulators out there that do just that. They run you about $150 or so. Check it out...
Victor
03-10-2008 09:56 PM
hi
i appreciate your help but what is the best simulator to use and can you provide me some good names for CCNP simulators which doesnot cost lot of money please
03-11-2008 12:29 AM
You can try Dynamips.. thats good simulator..
03-10-2008 11:53 AM
Never use a buzz word in an interview with a tech savoy interviewer. They will know if you actually know what you are talking about or if you just read it on NetPro.
Be honest if you have hands on or book knowledge.
ok enough about that...
It all depends on your application on what technology to use.
