Wan trunking
hi to all
kindly i wonder if i can do WAN trunking between two switch on differner site and subnet
Hall of Fame Super Blue
Re: Wan trunking
Hi Rashid
If the connection between your 2 sites is a layer 2 connection then yes you set this link up as a trunk and pass multiple vlan traffic.
If the sites are on different subnets though why do you want to do this. Remember that a trunk runs at Layer 2 and so Spanning-tree will extend between your sites.
Jon
Re: Wan trunking
dear jon
many thanks for your fast replay
kindly ,i have CRA server and i want recording and montoring of the agents for another site on Unique server .please find the portion of configruation on core SW
description To Reflector Ports of SW3
switchport access vlan 800
switchport mode trunk
Spanning-tree portfast
and then access SW
description Reflector Port
Monitor session 1 destination remote vlan 800 reflector-ports
note Vlan 800 is for span&rspan
Re: Wan trunking
I understand why you want to do this now. The question remains the same, what type of connectivity do you currently have between your sites. Is it yours or is it provided bt an SP.
As Mounir suggested if it is ISP owned you can talkt to them about Q-in-Q and you could also look at L2TPv3 which allows you to extend a layer 2 vlan across a layer 3 link.
Jon
Re: Wan trunking
What is the intermediate connectivity type? your provider can offer Q-in-Q for such case if they support it.
159
