Way to aggregate 2 DS3 other than multilink PPP ????
hi all
are there any way t to aggregate  2 DS3 other than multilink PPP , in way that can group this  2 unchannlized DS3s and work as a bundle interface.
Giuseppe Larosa
Hello Mohamed,
I would suggest to use them as two L3 parallel links
flow based CEF load balancing provides good results with usual traffic patterns
Hope to help
Giuseppe
dear Mr gisular
my problem actually that i have two 7200 router that connected through two DS3s one of them is VXR the other is NPE-g2 , the VXR router is connected to ADSL DSLAMs the other is connected to the Raduis server and the are already loading balancing using EIGRP , but the problrm is when the clients tries to connect they authenticate two times through two different interface which leads to wrong information on my radius , and when i used multiPPP
the CPU uitltization was very high on ,my router
now i\m searching for a way to load balance and in the same time use bundle interface that can make clients authenticate from same IP address as source interface
thanks alot
Hello Mohamed,
I think a possible solution would be to force the source of radius packets to be for example a loopback interface
ip radius source-interface ?
this should make consistent the way they appear to the radius server
Hope to help
Giuseppe
hi Mr gisular
i think that would solve the problem thanks alot
