Community Member
WCCP 1 working, WCCP 2 not working on Cisco 6500
Hi;
Although we successfully configured and run wccp version 1 on cisco 6500 (sup 720, ios ver : 12.2.(33) SXH), we couldnt be able to with wccp version 2. We see the redirected packets on 6500 but no one going out net.
We want to use https redirection so we need version 2. Here is the configs with version 1 and 2. Whats wrong with it ?
Thanks.
WCCP1;
ip wccp web-cache redirection-list 30
access-list 30 deny ip x.x.x.x
access-list 30 permit any
interface vlan 1
ip wccp web-cache redirect in
WCCP2;
ip wccp 0 redirection-list 30
ip wccp 70 redirection-list 30
interface vlan 1
ip wccp 0 redirect in
ip wccp 70 redirect in
(we try "ip wccp web-cache redirection-list 30" instead of "ip wccp 0 redirection-list 30" on wccp2 but nothings changed)
Everyone's tags (2)
Community Member
Re: WCCP 1 working, WCCP 2 not working on Cisco 6500
Did you find a solution for this? I am running into the same issue. Because we have ver 1 running for another company, how would this affect them if we configure ver 2 for us? Can we run the two versions together or is ver 2 backward compatle?
thanks
Community Member
Yes, we found. On backbone side we didnt change anything. We use linux machine and mcafee wsg  as a proxy. We install redhat 5 on the server and reinstall mcafee wsg, then problem is solved automaticly.
version 1 only web caching but in version 2 you can use http,https etc. I think you can configure version 2 without any problem.
1076
