Webcast-Catalyst9k
WCCP and Multicast
We have Juniper WX for compressing the traffice between different location. Currenlty it is in-line position. We would like to set it up "off-path" , which will be connected to 6509 IOS switch. We need to enable the wccp and muticast in the switch. Here is portion of switch configure:
interface GigabitEthernet5/1
description Connection to Core_RTR-Gi5/1
ip address 192.168.210.49 255.255.255.252
interface Vlan2
description Corporate Segment
ip address 192.168.31.252 255.255.255.0
standby 2 ip 192.168.31.254
standby 2 priority 105
standby 2 preempt
The port 5/1 in the switch will be connected to edge WAN router and the Juniper will be connected VLan 2.
How we configure wccp v2 and muticast in 6909 switch? Please help
1 REPLY
Hall of Fame Super Silver
Re: WCCP and Multicast
Hello Ken,
1) multicast
conf t
ip multicast-routing
int g5/1
ip pim sparse-dense-mode
int vlan2
2) WCCP
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/wccp.html
The following example shows a general WCCPv2 configuration session:
Router# configure terminal
Router(config)# ip wccp web-cache group-address 224.1.1.100 password alaska1
Router(config)# interface vlan 2
Router(config-if)# ip wccp web-cache redirect out
Note: this may fit or not in your scenario use the doc to understand
Hope to help
Giuseppe
286
