Webcast-Catalyst9k
Web access to switches
What username and password is required on switches so you can browse to them via http?
rgds
Phil
1 ACCEPTED SOLUTION
Re: Web access to switches
Phil,
If you have local usernames configured on the switch, then you need to configure the following command which will prompt for username & password
username admin privilege 15 secret
ip http authentication local
Narayan
Gold
No username and enable password like password
M.
Can you explain your last comment more clearly - thanks.
I thought it was adding a privilege 15 level username, but that doesn't work.
Bronze
hi phil,
First you need to enable ur switch for using http server
then by using the enable password u set on the switch u can access the switch via http
No need of username to access the switch via http only by entering password is enough to login into the switch.
Hope this helps you,
Raj
Phil,
Narayan
244
