weight/metric and BGP default route from provider
I am getting two default routes from my two ISPs via BGP. Since the routes are now equal in weight/metric my outbound traffic is being balanced out both provider circuits. How can I add a weight or metric to one of the two so it becomes the preferred outbound connection?
Diego
1 ACCEPTED SOLUTION
Re: weight/metric and BGP default route from provider
Both ISP is connected to one router and you only received default route from both not full internet routing table?
Try this...
route-map DEFAULT-PREFERRED permit 5
match ip address prefix-list DEFAULT
set weight 150
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
! ...and put the route-map to your preferred ISP for outgoing traffic
neighbor a.b.c.d route-map DEFAULT-PREFERRED in
To make it work...
Router# clear ip bgp a.b.c.d soft in
Alternatively, you can block all incoming BGP advertisement from your upstream and just put a default route to both with higher AD to non-preferred ISP.
ip route 0.0.0.0 0.0.0.0 a.b.c.d 10 name preferred-isp
ip route 0.0.0.0 0.0.0.0 w.x.y.z. 20 name non-preferred-isp
Dandy
You can use local preferance for that.
Try this...
set weight 150
To make it work...
Dandy
Thank you sir. Your route-map option did the trick!
Diego
359
