Weird interface on a 2610XM... "NVI0"
Hello Netpro,
I discovered an interface called "NVI0" on an 2610xm running with IOS "c2600-spservicesk9-mz.123-14.T3.bin"
I wasn't able to find any documentation about this interface type, does anyone know what this interface is about?
It doesn't show up in the running config, I can't delet it, I can't clear it...
It is just visible with "show ip interface brief" and "show interface"
NVI0 is up, line protocol is up
Hardware is NVI
MTU 1514 bytes, BW 10000000 Kbit, DLY 0 usec,
Encapsulation UNKNOWN, loopback not set
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
Regards, Dirk.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Weird interface on a 2610XM... "NVI0"
Dirk
A quick look at the documentation reveals that the NVI is the NAT Virtual Interface which was apparently introduced in 12.3(14)T. With this new feature you no longer need to configure NAT inside interface(s) and NAT outside interface(s). So yes you would not be able to delete it, since it is defaulted into existance by this version of IOS.
This link will provide more information about this new feature:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a008041d91a.html
Rick
Dirk
Rick
Hello Rick,
I was just searching for "NVI0" and couldn't find anything. Thanks for your help!
I will then allow NVI0 to make itself at home on my routers. :-)
Regards, Dirk.
768
