Community Member
Weird NAT behaviour
I'm on a 886VAW ( 15.1(4r)M ). I have a setup  as follows:
One internal host is portforwarded via static NAT ( NAS with an app on it which I want to publish ).
Other hosts are dynamically NATed.
All internal hosts to be excluded from NAT for certain VPN destinations ( RFC 1918 <-> RFC1918 ).
The WAN link is a 6 MBit ADSL line nailed down via ATM.
I have only one dynamic 24h - WAN IP and, in this sceanrio, I need to use static and dynamic NAT together.
The DDNS is performed via NO-IP.
There is no packet filter anywhere ( yet ).
All engines running nicely, but I cannot reach the forwarded host under certain conditions from the outside.
The behavior is this:
iPhone app connecting via 3G to the host app --> OK, everything runs.
iPhone tethered to a Laptop, Laptop connects to the host app via the iPhone 3G --> OK everything running.
Office machine running off a SDSL link behind a ASA5510 -> OK, everything running.
Normal Standalone PCs ( independent of OS, location / machine type etc ) and non-Iphones ( meaning samsung and the like ):
The application loads partly; I can see the title of the program in the Firefox tab. AGES later the splash screen comes alive.
Then the browser freezes.
These machines run off normal consumer DSL lines or 3G cellular service.
Bandwidth is NOT an issue.
Again, BUT:
A standalone PC as mentioned above, tethered via personal hotspot to the iPhone, CONNECTS !!!
So much for confusion.
According to the NAT table, the connection IS established:
#sho ip nat trans
Pro Inside global         Inside local          Outside local         Outside global
tcp      ---                   ---
Here's my setup. I can not figure what is causing this behavior....The ACLs in square brackets are for VPN control ( remaining VPN setup not posted here ). There is only 1 Dialer ( even if the one below has the index #2 ).
interface Dialer2
ip ddns update ***
ip ddns update *****
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 2
dialer idle-timeout 90
dialer string "*99#"
dialer-group 1
ppp authentication pap callin
ppp pap sent-username ****
ppp ipcp dns accept
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
no cdp enable
crypto map ****
ip nat inside source static tcp 80 interface Dialer2 80
ip nat inside source route-map natexclude interface Dialer2 overload
ip route Dialer2
access-list 90 permit
access-list 120 permit ip any
[access-list 198 deny   ip]
access-list 198 permit ip any
[access-list 199 permit ip]
dialer-list 1 protocol ip list 120
no cdp run
route-map natexclude permit 10
match ip address 198
Everyone's tags (3)
Community Member
Re: Weird NAT behaviour
In you failed scenario have thought of running a packet capture on the PC it may give some hints. Use Wireshark which free. One possible cause could be an MTU issue.
You could reduce ip tcp adjust-mss to a lower value.
