Bronze
weird scenario! switch, ip phone
HI every body!
Please consider the following configuration
sw-----------------ip phone----pc
switchport voice vlan 3
switchport mode access vlan 4
switchport trunk native vlan 5.
The result is:
voice frame will use vlan 3 and pc data frame will use vlan 4
Now consider the following Scenario:
sw1------------sw2
sw1
switchport trunk encapsulation negotiate
switchport trunk native vlan 2
switchport mode access vlan 3
what would be the result?
1) would vlan 3 frames on the trunk will be untagged or native vlan 2?
2)In first example, we see that a port is in vlan 4 and still be configured for trunk with ip phone.
Is it only possible if switch port is connected to ip phone?
thanks a lot!
Hall of Fame Super Silver
Re: weird scenario! switch, ip phone
Hello Sarah,
some switch commands are effective only when the port is in trunk mode
this is the case of
switchport trunk native vlan X
switchport trunk enc negotiate
if the port has config
switchport
switchpor mode access
switchport access vlan 4
the commands that specify what the port will do if it is a trunk have no effect.
The port is an implicit trunk carrying only two vlans but it is still seen as in access mode
the command
sh int type x/y switchport
provides all this information includind voice vlan
To be noted that if you need to pass three vlans on the port you need to configure the port as trunk
In this way you will have one voice vlan and two data vlans
Hope to help
Giuseppe
Bronze
Thanks a lot Giuseppe!
A fellow net pro forwarded a very good link about it. .javascript:newWin('http://cciepursuit.wordpress.com/2009/01/01/group-study-good-explanation-of-the-voice-vlan/
As noted in above link, Cisco calls it multi-vlans acces port.
I just want to confirm one thing if the link has to carry more than two vlans say 3, it could not be configuured as muli-vlan access port so it must be configured as trunk. Am i correct?
to put simply an muli-vlans access port cannot carry more than two vlans right or wrong?
how about if we have following configuration
switch 'port f0/1---------ip phone---pc
switchport voice vlan untagged
Will this command cause ip phone and pc to use vlan 1 ? why? by default all ports are in vlan 1. Since f0/1 is not in any other vlan, it is therefore in vlan 1. IP phone will and pc will use vlan 1, ip phone will send untagged frame to switch.AM i correct?
thanks a lot!
Hi Sarah,
With configuration of multi vlan, particularly because the switchport is configured as access with voice vlan statements.
Yes
When using voice vlan untagged, even the voice frames from the phone fall into the access-vlan, because they are untagged (if the port is in access-mode) or the native vlan (if the port is int trunk mode).
Lejoe
Hello Sarah,
Correct the implicit mini trunk can carry only two vlans.
We actually use the switchport voice vlan command also on these trunk ports (switchport mode trunk)with 3 vlans.
Hope to help
Giuseppe
285
