Webcast-Catalyst9k
What do I do if I lost my enable secret password?
I'm connected to the console
Re: What do I do if I lost my enable secret password?
You need to go through the password recovery procedure. Just go on http://www.cisco.com and search for password recovery and the device type, for which you have lost the enable password.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Silver
Do you have older configuration?
If yes, you can decrept your password by following applet link..\
http://www.fastcrack.com/ciscopd7.html
http://www2.tongzweb.com/tools/cisco.asp
If you don't have older coonfiguration... You need to recover by console.. follow steps Password recovery from cisco site. *******(Beware about your configuration)*************************
Dharmesh Purohit
Gold
those tools only decrypt type 7 passwords. Enable secret uses type 5 (MD5). these are not trivial to retrieve. you will have to use password recovery and simply change the enable secret. hopefully password recovery hasn't been disabled.
137
