04-13-2009 10:07 AM - edited 03-04-2019 04:21 AM
I'm trying to run OSPF inside my network and I'm running Version: C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1).
Here's a "sh ver":
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
ALLEN-1.11.5-CoreSW uptime is 6 days, 5 hours, 21 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K byt
es of memory.
Processor board ID CAT1034ZHLB
Last reset from power-on
4 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:2F:B3:F2:80
Motherboard assembly number : 73-9897-06
Power supply part number : 341-0097-02
Motherboard serial number : CAT10335QW4
Power supply serial number : AZS103003HV
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-24TS-S
System serial number : CAT1034ZHLB
Top Assembly Part Number : 800-26160-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMG00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24TS 12.2(25)SEB4 C3560-IPBASE-M
I understand I need an IP Services Image. Can I upgrade to: c3560-ipservicesk9-mz.122-50.SE.bin?
If not, does anyone know which IOS file I can upgrade to, to use OSPF?
Solved! Go to Solution.
04-13-2009 10:25 AM
Mike,
Actually, You can upgrade the new version of the same IOS feature set, IPBase as long as services(aka SMBSA) you bought at the first time.
In case you want to upgrade to the new ios feature set like IPService. You need to pay for that.
My 2 cents,
Toshi
04-13-2009 10:13 AM
Mike,
IPservice image is what you need. Yes,You can upgrade.
Note: Just to make sure that you got that image from the right place.
Toshi
04-13-2009 10:15 AM
Mike
You do need IP Services. You can choose any release as long as you get the right feature set so yes you could go for c3560-ipservicesk9-mz.122-50.SE.bin but you could just as easily upgrade to the IP Services Feature set of the current IOS version you are running, up to you really.
Note that there will be an additional cost to go to IP Services from IP Base.
Jon
04-13-2009 10:20 AM
"You do need IP Services. You can choose any release as long as you get the right feature set so yes you could go for c3560-ipservicesk9-mz.122-50.SE.bin but you could just as easily upgrade to the IP Services Feature set of the current IOS version you are running, up to you really.
Note that there will be an additional cost to go to IP Services from IP Base"
I haven't been able to find the IP Services for the current IOS version.
When you say "cost", do you mean a price to pay to upgrade, or the effect it will have on the switch when I do upgrade?
04-13-2009 10:25 AM
Mike,
My 2 cents,
Toshi
04-13-2009 10:28 AM
Mike
"I haven't been able to find the IP Services for the current IOS version"
Yes, seems like it's not available. Any IP Services will do though.
Cost as in money unfortunately.
Jon
04-13-2009 10:38 AM
"Cost as in money unfortunately."
I was able to download: c3560-ipservicesk9-mz.122-50.SE.bin for free from Cisco. The .bin file is all I need right?
04-13-2009 10:41 AM
Mike
Yes the .bin file is all you need. There is nothing to stop you downloading from Cisco but that doesn't mean it's free. You should talk to your Cisco reseller if you have one.
Jon
04-13-2009 10:47 AM
Ahh..I see. Thanks.
04-13-2009 10:27 AM
Please perform a "dir all-files"
You need a minimum of 128MB of DRAM and 16MB of Flash.
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory
This shows that total DRAM. You add them together to get about 240MB of RAM.
The "dir all-files" will show you how much Flash you are using and what you have left.
Victor
[EDIT] I kept my response window open for so long as I ate lunch that I didnt know that a hundred people answered already. LOL
But he does need to check his Flash, though.
The sh ver only shows DRAM, not flash.
[EDIT]
04-13-2009 10:41 AM
"But he does need to check his Flash, though."
32514048 bytes total (25494528 bytes free)
04-13-2009 10:49 AM
Victor,
That's fine. As long as you had lunch and got full after that. (grin)
Mike,
Your flash space is okay. Like Jon mentioned, you need to contract re-seller. It's not free anyway.
Toshi
04-13-2009 10:54 AM
Thanks for the quick response guys. Much appreciated!!!
04-13-2009 01:53 PM
You should have shown your appreciation by jazzing us all up with 5 points each :-)
04-13-2009 02:00 PM
LOL..whats up, Toshi.
Actually, lunch wasnt that great. Just some carrots, an apple and a banana...
