04-13-2009 10:07 AM - edited 03-04-2019 04:21 AM
I'm trying to run OSPF inside my network and I'm running Version: C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1).
Here's a "sh ver":
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
ALLEN-1.11.5-CoreSW uptime is 6 days, 5 hours, 21 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K byt
es of memory.
Processor board ID CAT1034ZHLB
Last reset from power-on
4 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:2F:B3:F2:80
Motherboard assembly number : 73-9897-06
Power supply part number : 341-0097-02
Motherboard serial number : CAT10335QW4
Power supply serial number : AZS103003HV
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-24TS-S
System serial number : CAT1034ZHLB
Top Assembly Part Number : 800-26160-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMG00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24TS 12.2(25)SEB4 C3560-IPBASE-M
I understand I need an IP Services Image. Can I upgrade to: c3560-ipservicesk9-mz.122-50.SE.bin?
If not, does anyone know which IOS file I can upgrade to, to use OSPF?
Solved! Go to Solution.
04-13-2009 02:04 PM
Victor,
I'm good, what about you?
After reading all comments in this thread again. Just want to give you 5P!. Not sure why though! (grin)
Toshi
04-13-2009 02:07 PM
Toshi! My man!
Thanks...
Im OK, man...economy here sucks big time. Work is slow...people getting laid off.
Where are you located?
04-13-2009 02:11 PM
Victor,
I'm from the crypton planet in which the superman was born. Just kidding(grin) I'm from Thailand(Asia). I've got problems because the economic crisis as well.
Nice to see you here.
Toshi
