what is command to show any protocol on interface of GSR12000 with XR OS
I would like to know command which show any protocol on that interface (same as "ip cache-flow) of GSR 12000 with XR OS.
Bryan Garland
If you setup netflow under the interface then you can use the command "show flow monitor cache format record location 0/0/cpu0" as an example.
http://www.cisco.com/en/US/partner/docs/routers/xr12000/software/xr12k_r3.9/interfaces/configuration/guide/hc39nflo.html
Here is an example of the command output:
http://www.cisco.com/en/US/partner/docs/ios_xr_sw/iosxr_r3.8/interfaces/command/reference/hr38nflo.html#wp1272518
Bryan
