What is OSPF Authentication used for
rdanieldrew1
I am studying for my CCNA Security and just came across a video talking about OSPF Authentication, but didn't really explain why it would be used.
I know the purpose behind it is to send the routing updates securely, but why would you need this, if all other aspects of your network are secured?
A good best practice is use specific /32 networks into the routing protocols to create adjacencies but imagine some network administrator have the following config:
interface g0/0
description TO-HQ
ip address 10.0.10.2 255.255.255.0
no shutdown
router ospf 1
network 10.0.0.0 0.255.255.255 area 0
or
network 0.0.0.0 255.255.255.255 area 0
All the network could be receive routing information or create adjacency with rogue devices (not authorized devices) over some network 10.x.x.x. From my point of view good practices are:
- Configure as passive LAN interfaces
- Set up the specific IP address to create adjacency, for example use: 10.0.10.2 0.0.0.0
- Authentication creates a protection layer to avoid any misconfiguration,  So not all the device will be able to participate into the routing domain without a password.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
5 Replies 5
Yachay
Essentially, authentication is used to recognize which router can participate exchanging OSPF messages. For instance, a company has 4 routers and for security reasons, they are going to use OSPF authentication. Every router will have the same password and key id, so they are going to form a OSPF neighborhood. Let's say a fifth router is connected to the network with no good intention (it is connected to inject fake routes to fake sites.) If that router does not have the same password and same key id, it will never participate into the OSPF messages and obviously, it will never modify the routes.
interface g0/0
description TO-HQ
no shutdown
router ospf 1
or
Hope it is useful
BTW, later Cisco OSPFv2 implementations also support the OSPFv3 syntax, where you can place an interface into OSPF using an interface command rather than an OSPF process network statement.
Hello
Basically to protect unwarranted ospf adjacencies from from forming within your ospf processes/domain and also protect these rtrs from exchanging routing updates to unwarranted ospf peers
res
Paul
Kind Regards
Paul
Joseph W. Doherty
By default, an OSPF device will form an adjacency with any other OSPF device as long as they have common attributes, such as network and area parameter (which can be determined by watching what an OSPF device is transmitting in its hello packets).
Also by default, OSPF edge networks (e.g. user networks) will allow an OSPF adjacency.
OSPF authentication helps insure an OSPF adjacent device is authorized to exchange routing information with your device.
