What is OSPF interface priority?
webstd.design
How can I config and see this parameter?
spremkumar
Level 9
Level 9
OSPF Priority is used to influence the DR/BDR selection process.
You can view the priority using show ip ospf interface command to check the priority set under the interface.
you can alter the same using ip ospf priority under the interface mode.
regds
