Spotlight January 2018 Silver
What is the max numbers of Point-to-Point E1's a 3845 can handle?
I would like to know what is the max numbers of point-to-point E1 conections a 3845 can handle? Which modules should I use if I need to have 6 E1 connections?
Thanks a lot for your time
Lp
1 REPLY
Re: What is the max numbers of Point-to-Point E1's a 3845 can ha
You can manage 8 E1's using 4 x NM-2CE1T1-PRI:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080189f95.html
I assume that this amount can also be reached using 4 x VWIC2-2MFT-T1/E1: 2-Port T1/E1 Voice / WAN with drop and insert.
Anyway, 6 E1's wil not pose a problem.
regards,
Leo
110
