What module to use?
For a 3800 series router, what module can i use for a dedicated 100MB fiber connection.
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Re: What module to use?
The 3800 series routers come with one dual purpose Gigabit port. By defualt the media-type is RJ-45.
You can use the SFP module (GLC-SX-MM= , if it is multimode)on this port and change the media-type to support fiber.
interface gi 0/0
media-type SFP
HTH, rate if it does
Narayan
Silver
It depends on the fiber type the connection will be served. You will have to use the appropriate SFP.
Krisztian
interface gi 0/0
media-type SFP
Narayan
The model below seems to support a "SFP" module. That may be your only option for a 100Mb Fiber (ethernet). I don't remember if the 3800 has SFPs onboard. If they do, you don't need the switch module just the SFP.
NME-XD-24ES-1S-P
Link:
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8028d15f.html
Fiber SFPs:
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd8033f885.html
103
