What route do I use when using a DSL line?
Hey guys,
I have a DSL business line and the ISP gave me /29 network. I set the DSL modem as Bridge mode and I have a Cisco 877 acting as the PPPOE client.
What do I use in my ip route 0.0.0.0 0.0.0.0 statement?
Do I put:
ip route 0.0.0.0 0.0.0.0 dialer1?
The ISP only gave me the block of 5 IPs and told me to use the last one as the default gateway, however, this IP gets placed in the dialer1 interface after I connect the router to the DSL (I found this by doing a "sh ip int br")
Any help?
Re: What route do I use when using a DSL line?
Assuming your dialer1 is the interface going to ISP, YES.
Well, physically, my FAS4 interface is the one connected to the DSL modem.
FAS4 settings:
interface FastEthernet4
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
end
Then I have a Dialer1 interface. Here are its settings:
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname user@sbcglobal.net
ppp chap password xxx
ppp pap sent-username user@sbcglobal.net password xxx
end
I hope this info helps.
Angel,
Though FastEthernet4 is your physical connection to the ISP dialer 1 is where the IP configuration resides on. Therefore, as you indicated earlier, you need to point the default route to dialer1.
Sundar
I see. But my confusion comes in here:
The ISP gave me an /29 network. (75.75.75.128/29). Then they told me to use 75.75.75.134 as the Default gateway and 255.255.255.248 as the subnet mask.
But when I do a "sh ip int br", 75.75.75.134 shows as the IP address for the Dialer1 interface. So how in the world am I going to use .134 as the D.G?
Based on this Network, .129 should be the default gateway and .130 up to .134 the usable IPs. Am I correct on this one?
Blue
Sundar:
If he points his default route to the dialer interface, wont the router execute an ARP for every destination address, since it will think that the destination addresses are all directly connected to dialer 1? And in that case, wont the ISP's router have to have proxy ARP enabled?
If they are giving him a default gateway address to use, why cant he just point his default route to that and be done with it?
Thanks in advance for your time and response.
Victor
Victor,
You are correct that when a route points to an interface the router would rely on proxy ARP response from the device connected to the interface and moreover proxy ARP also puts extra burden on the router originating the ARP. It wouldn't be an ideal setup but there are situations that would require this configuration like when the next hop address is unknown or the IP of the interface is dynamically negotiated.
Angel,
You are correct that the route can't point to it's own address as the next hop. The router would spit out an error if you try to do that. However, you can point the route to dialer1 interface. I assume your ISP probably may have meant to say the same.
Just point the default route to dialer1 int and check the outcome.
Sundar
Every provider uses his own technique and design. Here in holland routed subnet configuration are used a lot. The config would look like this.
interface Dialer0
ip unnumbered Ethernet0
interface Ethernet0
ip route 0.0.0.0 0.0.0.0 Dialer0
In this setup the router is used more as a modem and a firewall or router device after the DSL router can use ip addresses in the public range with the router as Default GW.
For the routed subnet configuration you also should remove the "ip nat outside" line.
Of course you can also choose to use a natted config on the DSL router.
Seems like Im having way too many problems with th is line.
Last night, I was able to put some traffic on this line. It is used as my backup ISP and this is the config I had for my Dialer1 interface and also for the FAS4 interface (fas4 is where the dsl line is physically connected into the 871 router)
no ip address
duplex auto
speed auto
end
interface Dialer1
mtu 1492
ip access-group 111 in
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp pap sent-username user@sbcglobal.net password 7 111F1F1740475B
crypto map mymap
end
ip route 0.0.0.0 0.0.0.0 69.69.69.25 track 125
ip route 0.0.0.0 0.0.0.0 Dialer1 200
ip nat inside source route-map GlobalISP1 interface Dialer1 overload
ip nat inside source route-map GlobalISP2 interface Vlan3 overload
Like I said, last night it worked but the line was dropping every 45 minutes or so. It would go down for 1 min. to 5 mins and then it would come back... so it was very unstable.
Today we called the ISP and they provided us with a new DSL modem. Whe ISP tech finished, I couldn't even get an IP address. I then asked the tech to please set the DSL modem as a Bridge only device. He went ahead and did it, however I still can't even get an IP address; my dialer1 interface shows "unassigned" for the IP-Address.
I then placed my laptop and set it up as a PPPOE client and it worked. This is perhaps telling me that the cisco 871 is the culprit.
any help please?
Can you post your complete configuration please? You can attach it as an file.
Hall of Fame Super Gold
Posted config is complete enough to say it seems ok.
Please collect "debug pppoe-packet" and "ppp negotiation", with "term mon".
attached
Seems ok to me, can you post the output of the comments posted by p.bevilacqua.
please try and post the results of:
debug vpdn pppoe-events
show vpdn
debug vpdn pppoe-data
debug pppoe-errors
debug pppoe-packets
guys, thanks for checking. I also engaged with TAC and they also said the config looks good.
So I went back to those clowns (AT&T) and asked them to investigate what was happening. They had said that the line was dirty, then the DSL modem was bad, etc.
I went onsite and personally reset that modem, called their tier2 people to have them bridge that thing again and during this process, I noticed there are few settings that need to be setup properly, like disabling the routing feature of the dsl (because it will be in bridge mode). Perhaps these are the settings that were not completely setup the few times their field techs tried.
Soon after the DSL modem was properly bridged, the cisco router quickly obtained an IP address and traffic started to flow out the dialer1 interface.
It has now been more than 16 hours and the line has not had any problems... not even a hicup.
all good guys... thank you for the helping out and making sure my my config was golden
Good to know it has been resolved. Next improvement step for you, get an 877 or even better a 1801, so you can connect the dsl line directly and apply QoS on it.
Remember to rate useful posts with the scrollbox below and good luck!
253
