What's the difference between WS-C3750X-24P-L with WS-C3750X-24T-L ?
I want to buy cisco c3750x switch between WS-C3750X-24P-L with WS-C3750X-24T-L . I still have no idea to choose which one is worth to have, can someone give me the suggest?
VIP Purple
HI Bejiening,
Please check this link to compare both these models:
http://www.cisco.com/en/US/products/ps10745/prod_models_comparison.html
Hope it helps.
Dont forget to rate helpful posts.
Hall of Fame Super Gold
Re: What's the difference between WS-C3750X-24P-L with WS-C3750X
24P means it's 24-port PoE.
24T means it's 24-port non-PoE.
Sent from Cisco Technical Support Nintendo App
Super Bronze
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
BTW, ff you do need PoE, power planning is more involved as you also need to account for how much power your PoE devices will need to draw.  Also, if you have a stack of 3750-Xs, power planning might also use Stack Power.
In addition to what Joe has posted, can you please elaborate what you are trying to achieve. Personally, if I was given a choice, I'd consider looking at 3650 and 3850 instead of 3750X.
311
