Community Member
What should I do after being Certified?
I studied CCNP and took its certification but I feel that there is alot of information that i need to know and wasn't mention in the certification study guide.
what should i do next after taking the certifications so i become a real network professional? espcially there are alot of experts here may be they can give me a hint or encourage me to devolop myself
Talal Habeeb
Hall of Fame Super Bronze
Re: What should I do after being Certified?
I recommend getting some hands-on experience with routers and switches.
On the router side, go to this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/index.htm
and play with all the features.
On the switch side, go to this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/index.htm
By practicing from those two links, it will help you get a head start for a CCIE R&S certification if you wish to pursue it.
HTH,
Community Member
Thanks Edison for the useful links, i'll take my time to play with all these commands.
96
