what version do i need for "ip route ... track"?
i want to use the "ip route x.x.x.x ... track 1" command, and i don't have the "track 1" option in the end.
i don't know what the feature called, so i can't look it up (ip sla? what kind?)
i have 2651xm, with image "c2600-ik8o3s-mz.123-16a.bin" (Version 12.3(16a))
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: what version do i need for "ip route ... track"?
12.3 non-T will not work. T version have the latest technology, non-T does not.
You need atleast 12.3(8)T, to use this feature. Please see the release notes for enhanced object tracking feature:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801541be.html
HTH,Please rate if it does.
-amit singh
so if i have 12.3(16a) it should work, no?
I guess the the syntax is:
"track 100 ip route x.x.x.x/y reachability"
HTH, please rate if it does help,
Mohammed Mahmoud.
maybe i wasn't clear.
i don't need the track to fall down when the route is down in your example. i need the route to fall when the track is down. like i saw in 3800: "ip route 1.1.1.1 255.255.255.0 track 1" so the static route will work only when the track is up.
In Addition to all the posts i would like to suggest to check out the feature set of the ios version you are using.
Some of the track features may not be available even with latest version of IP Base feature set better to check out for SP Services set.
regds
thanks!
do you happend to know if i can download T version from somewhere?
You need a support contract (aka smartnet) with Cisco, to access the donwload area.
319
