When configuring MHSRP, group numbers per VLAN should be different?
I will configure MHSRP. Then,hsrp group numbers should be different per VLAN?
VIP Purple
Re: When configuring MHSRP, group numbers per VLAN should be dif
are you talking about MSHRP on VLAN (Layer 3) interfaces ? The group numbers would indeed need to be different...
GP
Typically the only time that it is critical to keep the group numbers different is when you are using multiple HSRP groups on the same VLAN. The group number affects the last octet of the HSRP MAC address. With multiple groups on the same VLAN you want each HSRP group to use a different HSRP MAC address.
Using different group numbers everywhere can help when looking at a Sniffer output from a trunk port, for example, since each VLAN will have a different MAC address. However, most switches use both the MAC address and the VLAN number internally so you can reuse the same MAC address and HSRP group numbers on different VLAN's.
consider using one group for on-subnet as a rule.
Tipycal config would look like this.
description (LAN1)
ip address a.b.c.d 255.255.255.192
standby 17 ip a1.b1.c1.d1
standby 17 priority 110
standby 17 preempt
standby 17 track GigabitEthernet6/16(e.g)
standby 32 ip a2.b2.c2.d2
standby 32 priority 110
standby 32 preempt
standby 32 track GigabitEthernet9/1(e.g)
interface Vlan21
description (LAN2)
ip address w.x.y.z 255.255.255.192
standby 19 ip w1.x1.y1.z1
standby 19 priority 110
standby 19 preempt
standby 8 ip w2.x2.y2.z2
standby 8 priority 110
standby 8 preempt
standby 8 track GigabitEthernet9/1(e.g)
219
