Which router Seril Cards for Bandwidth Upgrade from 128 to 256 Kbps
We need to upgrade our Mumbai ? Chennai - Leased Line Link from 128 Kbps to 256 Kbps.
Routers [Serial Cards] at Both ends
1) Mumbai End : CISCO 3661 [8 Port Async / Sync Serial Module]
2) Chennai End : CISCO 3640 [8 Port Async / Sync Serial Module]
Routers at both ends
Mumbai end : CISCO 3661
3660 Chassis type: ENTERPRISE
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
12 Low-speed serial(sync/async) network interface(s)
8 ISDN Basic Rate interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Read/Write)
Router at Chennai end : CISCO 3640
1 Ethernet/IEEE 802.3 interface(s)
8 Low-speed serial(sync/async) network interface(s)
4 ISDN Basic Rate interface(s)
16384K bytes of processor board System flash (Read/Write)
I believe this above 8 Port Async / Sync Serial Module support only speeds upto 128 Kbps. ? is it true.
If yes then would appreciate if you could ASSIST us for which Router Serial Cards are required at Both routers for supporting 256 Kbps leased Line.
1 REPLY
Re: Which router Seril Cards for Bandwidth Upgrade from 128 to 2
125
