Community Member
Why can't I create rows under CISCO-IPSEC-PROVISIONING-MIB::cipsIpsecXformSetTable?
On several ISR G1s and G2s running IOS 12.4 through 15.4 I can't seem to create rows under the SNMP table CISCO-IPSEC-PROVISIONING-MIB::cipsIpsecXformSetTable.  No matter what combination of indexes and columns I set in addition to cipsXformSetStatus, the SNMP agent always returns noCreation errors.
Why this should work:
  • This seems to contradict the MIB, which says that this table is read-create.
  • The MIB is listed as supported for my IOS images in SNMP object navigator.
Steps to reproduce:
Using net-snmp:
snmpset $host cipsXformSetStatus.1 i createAndWait
Results:
Reason: noCreation (That table does not support row creation or that object can not ever be created)
With SNMP debug on:
process_mgmt_req_int: UDP packet being de-queued
SrDoSnmp: received set pdu
CheckMIBView: OID is in MIB view.
FindObjectClassCore: findObject failed
do_sets: can't find object
make_error_pdu: Variable does not exist, and the agent cannot create it.
50
