Community Member
Why CTS is down
Dear All,
May I know under what kind of situation the CTS will show down, the circuit is running fine currently. thank you.
SATTSA1#sh int s1/0
Serial1/0 is up, line protocol is up
Hardware is M4T
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 55/255, rxload 167/255
Encapsulation PPP, LCP Open, multilink Open, crc 16, loopback not set
Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 12:41:35
Queueing strategy: weighted fair [suspended, using FIFO]
FIFO output queue 0/40, 33 drops
30 second input rate 1008000 bits/sec, 303 packets/sec
30 second output rate 336000 bits/sec, 281 packets/sec
4326297 packets input, 1378146069 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3868242 packets output, 520902997 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
2 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=down
Thank you,
1 REPLY
Hall of Fame Super Gold
Re: Why CTS is down
The "modem" you're connected to incorrectly keeps CTS down, or there is a cabling problem.
However, router sees DCD up and doesn't care about CTS.
Actually, in most cases, CTS/RTS are uninfluent on point-to-point synchronous circuits.
124
