why the flow of netflow collect not equal the flow of snmp polling
QFX527518
by use the cisco 7606.【Version 12.2(33)SRB5,Supervisor Engine 32 10GE】,when uset netflow collect the flow of app,and use snmp get the port traffic.but now,the flow of netflow not equal the traffic of snmp polling.why.
under is the router's config:
mls ip slb purge global
mls ip multicast flow-stat-timer 9
mls flow ip interface-full
mls nde sender version 5
no mls acl tcam share-global
mls cef error action reset
interface FastEthernet1/0/0
ip address x.x.x.x 255.255.255.252
ip flow ingress
speed 100
full-duplex
mls netflow sampling
interface FastEthernet1/0/1
ip accounting output-packets
ip flow ingress
no ip mroute-cache
speed 100
full-duplex
interface ATM1/1/0
no ip address
ip flow ingress
atm sonet stm-1
no atm enable-ilmi-trap
no atm ilmi-keepalive
interface ATM1/1/0.1 point-to-point
bandwidth 24000
ip flow ingress
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination x.x.x.x 9996
5 Replies 5
Giuseppe Larosa
Hello Qing,
this means that not all packets are processed by netflow but only one every N packets.
This has been introduced first on Cisco 12000.
It is a measure of scalability on devices that are hardware based the netflow process cannot be implemented in HW so for providing netflow stats without impacting on the high performance of linecards sampling has been introduced.
The price to pay is that short life flows like a DNS request are missed but it is used also on service provider networks.
Hope to help
Giuseppe
thx.when i delete mls netflow samping.question is still.
help!
Hello Qing,
I'm afraid I was not able to explain the question.
netflow sampling can be a need in your platform.
if one every 100 packets is sampled processed by netflow you should see a flow of 100 MB as a flow of 1 MB
Hope to help
Giuseppe
thx。now the problem have been resolved.
under the global config add command :
mls aging long 64
mls aging normal 32
Hello Qing,
interesting feedback: so after disabling sampled netflow and adding these two commands you see netflow stats that match snmp stats?
according to netflow command reference disabling sampled netflow is needed for the two commands to have effect
see
http://www.cisco.com/en/US/docs/ios/netflow/command/reference/nf_02.html#wp1012247
Hope to help
Giuseppe
