12-16-2005 01:22 PM - edited 03-03-2019 11:15 AM
I'm running a c3640 at home with 2 connections. 1 connection cable(charter communications, dynamic ip and outside nat interface) and Bell dsl(static). I'm currently routing certain traffic over the adsl line to the office and the non-office traffic over cable (for the additional speed).
I purchased a wic-1adsl to handle the dsl termination. All of the example configs I have looked into show ATM interface. I have upgraded several different revisions of IOS and my router only gives me Virtual-Access1 interface and no ATM interfaces.
The IOS version I am currently using is:
c3640-telco-mz.123-13b.bin
Has anyone out there run into a problem like this? I can configure the Virtual-template for a ppp connection but I need to set a pppoe connection. Any help is always appreciated.
12-16-2005 04:30 PM
Probably its the feature set (may be you need IP Plus) rather than IP only feature set to support this card.
12-16-2005 07:29 PM
thanks for the reply hank, I dug a bit deeper and found that I was using an older nm1e2w module instead of the 1fe2w modules. I now have the atm interface but am having problems with the config to get this line up.
I called up bellsouth to get my vpi/vci numbers so all of this is good. struggling lol
T
12-16-2005 09:45 PM
This config should work, once you know the correct VPI/VCI values.
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppoe
request-dialin
protocol pppoe
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
pvc 0/35 <--- most service providers use 0/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
PS: Please remember to rate helpful posts!
12-17-2005 07:20 AM
I've tried just about everything last night and I do appreciate your time in helping with this issue. I'll paste my config below. I want to explain what I'm trying to do here once you see my different static routes.
I live in the affected area from Katrina, before the storm I was able to vpn from an xp machine to my unix vpn server at the office to print, file share to samba servers etc etc. Post Katrina my vpn connections are very unstable. I have no idea what charter did but something isn't right. I ordered bellsouth dsl recently and my line works fine. I'm currently connecting the dsl to a linksys and using the 3640 for cable and routing office ip's over the linksys connection.
I want to terminate the dsl on the 3640 so I can set my tunnel up to route me some ip's from the office. The reason for this is Bellsouth is blocking ports 137,138 and 139 along with 25. Charter is blocking the same except 25. I figured I'll just tunnel through them like I did before
F0/0 - connection to charter ip set to dhcp nat outside
E1/0 - Internal net - nat inside
I just don't know what else to try.
Building configuration...
Current configuration : 3241 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname rtr-3640
logging queue-limit 100
enable secret xxxx
ip subnet-zero
ip cef
no ip domain lookup
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
interface Tunnel0
ip address 192.168.20.2 255.255.255.252
load-interval 30
tunnel destination x.x.x.x
tunnel mode ipip
tunnel key 4155857
interface ATM0/0
mtu 1492
no ip address
no ip mroute-cache
load-interval 30
bundle-enable
hold-queue 224 in
interface ATM0/0.1 point-to-point
pvc 8/35
interface FastEthernet0/0
ip address dhcp
ip nat outside
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
interface Ethernet1/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
half-duplex
interface Serial1/0
no ip address
shutdown
interface Ethernet2/0
ip address 192.168.21.1 255.255.255.252
load-interval 30
half-duplex
no cdp enable
interface Ethernet2/0.1
description Tunnel to office
ip address x.x.x.x 255.255.255.240
interface Serial2/0
no ip address
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
dialer pool 1
ppp pap sent-username xxxx
password 0 password
ip nat pool ovrld x.x.x.x x.x.x.x prefix-length 24 (charter communications ip)
ip nat inside source list 1 pool ovrld overload
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1 10
ip route 0.0.0.0 0.0.0.0 f0/0 5
ip route x.x.x.x 255.255.224.0 Dialer0 (office IP's /19)
ip route x.x.x.x 255.255.255.255 FastEthernet0/0 (office mail server)
12-19-2005 03:51 PM
Troy,
You are here talking about two ISPs and I hope your Charter network is already up and running as far as network connectivity to the Internet. Lets shut down that interface (TEST mode) and see if you are able to reach the internet through the DSL network. For this you will need to put ip nat outside on the dialer interface and create separate nat pool so that packets get NAT'd using the new ip address space. If that also works then you should have failover established across the two links.
04-23-2006 11:49 AM
dear thisisshanky
hello that the version this IOS you use to configuration it use cisco 3640 ??
thank you
beasystem
04-22-2006 02:52 PM
please
thisisshanky
can you help me i need urgent setup my wic-1adsl
i have my line adsl 2mb
Posted by: beasystem - Apr 22, 2006, 3:38pm PST
hello friend
can you help me ,
i have cisco 3640 and plug slot 0 WIC-1ADSL and i upgrde my IOS 12.4.7 the problem it no detect the WIC-1ADSL IT show only 1 interface and 4 serias
you have some ideia i can make to resolve this problem i want setup the interface atm 0
and it no show when i get shoe diag and show version
can you help me look my shows.
Slot 1:
Combo 1E, 2W Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.2 Board revision C0
Serial number 16212706 Part number 800-01789-05
FRU Part Number NM-1E2W=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 37 01 02 00 F7 62 E2 50 06 FD 05 00 00 00 00
FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 1:
DSL SAR (ADSL)
Hardware Revision : 2.2
Part Number : 73-4771-07
Board Revision : A0
Deviation Number : 0-0
Fab Version : 05
PCB Serial Number : JAB05370J60
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : WIC-1ADSL
show versions
Router uptime is 1 minute
System image file is "flash:c3640-js-mz.124-7.bin"
Cisco 3640 (R4700) processor (revision 0x00) with 118784K/12288K bytes of memory
Processor board ID 15887612
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
1 Ethernet interface
4 Serial interfaces
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
you can why the IOS no detect my WIC-1ADSL
and the WIC-1ADSL it can work slot 0 or 1, 2, 3
pelase send return
thank you..
beasystem
04-22-2006 02:38 PM
hello friend
can you help me ,
Slot 1:
FF FF FF FF
WIC Slot 1:
DSL SAR (ADSL)
Board Revision : A0
Fab Version : 05
RMA History : 00
show versions
4 Serial interfaces
pelase send return
thank you..
beasystem
04-22-2006 05:08 PM
hello friend
you knonw why my IOS no detect my WIC-1ADSL
it detect only interface1/0 and 4 seriais
and no detect WIC-1ADSL SLOT :1 WIC SLOT: ADSL
when o get show ver it no display wic-1adsl adn too show diag look.
Router uptime is 1 hour, 1 minute
4 Serial interfaces
show diag
Slot 0:
Mueslix-4T Port adapter, 4 ports
Hardware revision 1.0 Board revision B0
Serial number 6245389 Part number 800-02314-01
FRU Part Number NM-4T=
0x00: 01 54 01 00 00 5F 4C 0D 50 09 0A 01 00 00 00 00
0x10: 58 00 00 00 97 11 21 00 FF FF FF FF FF FF FF FF
Slot 1:
--More--
0x10: 60 00 00 00 99 10 21 17 FF FF FF FF FF FF FF FF
WIC Slot 1:
DSL SAR (ADSL)
Board Revision : A0
Fab Version : 05
RMA History : 00
Product (FRU) Number : WIC-1ADSL=
--More-- Product (FRU) Number : WIC-1ADSL=
EEPROM format version 4
0x00: 04 FF 40 00 2E 41 02 02 82 49 12 A3 07 42 41 30
0x10: 80 00 00 00 00 02 05 C1 8B 4A 41 42 30 35 33 37
0x20: 30 4A 36 30 03 00 81 00 00 00 00 04 00 FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
how i make to the ios detect my WIC-1ADSL
you know hoe i make this setup ??
please i waiting your return
beasystem
thank you
04-23-2006 06:39 AM
the vast majority of the time that I have seen a CIsco router not recognize an ADSL card it has been because if a bug. I recommend that you downgrade to a different 12.3 version than the one you are running. You may have to expereiment with the versions but I believe that is the thing to try at this point.
Hope this helps.
Please remember to rate all replies
04-23-2006 06:54 AM
Hello
travis-Denis
thank you
i try find the difefrent 12.3 bersion to download
and i tru again plug the wic-1adsl to see if the new ios detect it when i get show ver..
whats the version you use cisco 3640 ?
im have the version 12.4.7 and it no detect wic-1adsl i too try 12.4.5a. too no detect it - plug it in slot 0 module 1E 2W w0
you have ideia what can be this problem ??
im gratefull
thank you
beasystem
nice day
04-23-2006 08:58 AM
I thought from your original post you were running 12.3 but it seems that you are runnnig 12.4 correct? I would start here
with a 12.2 GD release and work my way up
Hope this helps.
04-23-2006 09:45 PM
not sure if anybody has already mentioned this, but the WIC-1ADSL is not supported in the NM-2E-2W:
WIC-1ADSL
3600
Supported in:
NM-1FE1R2W
NM-1FE2W
NM-2FE2W
NM-2W
Not supported in:
NM-1E1R2W
NM-1E2W
NM-2E2W
So you need to install it in either of the supported modules.
GNT
04-29-2006 06:42 PM
Thank you
im purchase the new module NM-1fe2w to plug the wic-1adsl
now can you help me how i make to update my memory flash 4MB i have 2 16MB flash total = 32mb flash i removed the 1 4mb in when o power the cisco it enter rammon 1> whats i need make now i have the IOS 12.4.7 how make to setup rammom1 > and i upload the my IOS 12.4.7 ok.. thank you
beasystem
04/29/06
