09-16-2008 11:27 AM - edited 03-03-2019 11:34 PM
Hello everyone. I have a very simple question regarding a 2800 router and WIC-1DSU-T1 cards. The 2800 has HWIC and NM slots, I was working under the assumtion that an HWIC slot would accomadate a WIC card, but the router will not discover these devices and assign them a port as many other routers that I have worked with do. I have tried various IOS with the same results. Any suggestions? Thanks in advance!
Solved! Go to Solution.
09-16-2008 12:12 PM
It's possible you might need to define the WIC card added via the controller command. Don't have access to a 2800 at the moment for an example, but if this is the situation, good chance someone else will provide more info.
09-16-2008 12:12 PM
09-16-2008 12:41 PM
Hi, the product guides for the 2800 list a V2 of WIC-1DSU-T1 (see http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html#serialwan).
If your WIC is the older version, it may be that it's not compatible.
09-16-2008 02:18 PM
True enough... Follow up question, would the T1/E1 ports on http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet09186a0080191d41.html (NM-HDV2-2T1/2E1) perform the same function as a pair of WIC-1DSU-T1 would? Does the NM card have the DSU functionality onboard like the WIC does?
