Community Member
WIC-1DSU-T1 and 2800 series router
Hello everyone. I have a very simple question regarding a 2800 router and WIC-1DSU-T1 cards. The 2800 has HWIC and NM slots, I was working under the assumtion that an HWIC slot would accomadate a WIC card, but the router will not discover these devices and assign them a port as many other routers that I have worked with do. I have tried various IOS with the same results. Any suggestions? Thanks in advance!
1 ACCEPTED SOLUTION
Super Bronze
Re: WIC-1DSU-T1 and 2800 series router
It's possible you might need to define the WIC card added via the controller command. Don't have access to a 2800 at the moment for an example, but if this is the situation, good chance someone else will provide more info.
Super Bronze
Community Member
Hi, the product guides for the 2800 list a V2 of WIC-1DSU-T1 (see http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html#serialwan).
If your WIC is the older version, it may be that it's not compatible.
Community Member
True enough... Follow up question, would the T1/E1 ports on http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet09186a0080191d41.html (NM-HDV2-2T1/2E1) perform the same function as a pair of WIC-1DSU-T1 would? Does the NM card have the DSU functionality onboard like the WIC does?
699
