WIC-1DSU-T1-V2
artnc5583
I have a C2621 and trying to install a T1 card.
It does not show any servivce-module or controller commands.
The software version in good when compared to the requirements guide.
How do I configure the card in the router for T1?
6 Replies 6
dmorrison
The single port T1 cards require no configuration.
Arthur
Perhaps we could provide better answers if we had more information to work with. As a start can you provide the specifics about what T1 card you are trying to install? And can you provide the specifics of the version of code that you are running? Can you post the output of show version so that we can see if the card shows up?
Rick
Rick
Arthur
I have done some checking about the WIC-1DSU-T1-V2 and I find this in an document about the card:
The Cisco T1 DSU/CSU -V2 WIC is supported on the Cisco 1700 Series,       2600XM Series, 3631, and 3700 Series routers, and Cisco ICS 7750       software.
see this URL for additional details
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a0080093d70.shtml
So can you tell us whether your router is a 2600 or a 2600XM?
Rick
Rick
Good morning Richard
Thank you for looking at this
My Router is an C2621 and I cannot find any thing that suggests its a C2600XM.
When I try to show devices I cannot see the card.
I attached a print out of my IOS.
show version
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(3), RELEASE
SOFTWARE (fc2)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 19-Aug-03 16:32 by dchih
Image text-base: 0x80008098, data-base: 0x819AF6CC
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
System image file is "flash:c2600-ik9o3s3-mz.123-3.bin"
cisco 2621 (MPC860) processor (revision 0x600) with 56320K/9216K bytes
of memory.
Processor board ID JAD054906Z3 (651052972)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
GATEWAY(config)#int fa0/0
GATEWAY(config-if)#exit
GATEWAY(config)#int s0/0
% Invalid input detected at '^' marker.
GATEWAY(config)#int s0/0/0
GATEWAY(config)#int serial0/0
Arthur
Thank you for the additional information. The show version seems to indicate that your router is 2621 and not an XM. And if the information in the URL is accurate then this card is only supported in the XM version of the routers. So it looks like the card and your router are not compatible.
Rick
Rick
Richard
Thank you for the input
After reading several documents online, I thought it would be good to
get another opinion. Some papers indicated it may work and others said
no.
Thank you
Arthur
