WIC-1ENET in 3620 PROBLEM
Hi. I have a problem. Last week a bought a Cisco 3620 router with 2x Ethernets and 2xToken rings. I had put a wic-1enet card from my cisco 1720 router to the 3620. It doesn't work with this interface. Waht is the problem? the cisco IOS verison is 12.2(23)
Re: WIC-1ENET in 3620 PROBLEM
Module WIC-1ENET is not supported on 3600 platform.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
HTH,
-amit singh
did u reset your box after inserting the card ? i guess 3620 arent OIR capable so u need to do a reset so that the box can detect or sense the card.
also can you paste show diag and show version o/p taken from your box ?
regds
Only 1700s support WIC-1ENET>
150
