WIC-1T to RJ45 E1
My SP has provided me with a balanced E1 terminating as RJ-45. I have a router with a WIC-1T.
Is there any way to connect this up, I can't seem to find a cable that will do it?
Silver
Re: WIC-1T to RJ45 E1
Is it true that if you use the WIC-1DSU-T1, then you can't use all the E1 timeslots?
So the Vwic is the only integrated solution?
Silver
Yes, WIC-1DSU-T1 can only use 24 timeslots. In addition, E1 circuits use different line coding and framing than T1 uses. The WIC-1DSU-T1 will not be compatible with these differences.
Brad
284
