03-20-2006 04:42 AM - edited 03-03-2019 12:06 PM
Sir ,
I am attaching the output of serial controller of WIC-1T card .
What I understand is that Clock from Media Service Provider is not being detected by WIC-1T card ?
Can some more troubleshooting be done so as to finally resolve problem...
regds,
aman
Solved! Go to Solution.
03-20-2006 05:00 AM
Hi Aman,
DTE Unknown (13) clocks stopped" this error message you get when either you have a bad DTE cable or its the wic card.
Please try swapping the DTE cablewith a spare one.Can you swap this card with the any another if you have one.
regards,
-amit singh
03-20-2006 04:55 AM
In most cases the message "DTE Unknown (13) clocks stopped" is due to a faulty WIC.
Hope this helps,
03-20-2006 05:00 AM
Hi Aman,
regards,
-amit singh
03-26-2006 11:40 PM
DEar Amit,
We had changed the Serial cable along with WIC card..Problem is resolved.
regds,
aman
