WIC-1T
HI,
I am confusing which cable i have to choose for 1 port WAN interface,is RS-232 or V.35?
Re: WIC-1T
What is the termination of your modem?its a V.35 or an RS-232?Dpending on that,the cable will be selected.
Pls give the make and part no of your modem...it will help us.
JD
Re: WIC-1T
This is not related to your WIC-1T. It rather depends on the type of connection you have:
On the WIC-side, all connectors are the same but you need to order the correct cable for your modem/interface.
You should check with the provider of the leased line which interface will be used.
Leo
Re: WIC-1T
The router will connect to 1.5Mbps lease line.
Re: WIC-1T
Can u give the modem make and part no?
JD
Re: WIC-1T
That still doesn't say anything about the interface. It is likely to be either X21 or V35 but as I stated previously, you will have to ask the provider about this.
Leo
Re: WIC-1T
but the modem is provide by the ISP,we have to ask from them?
Re: WIC-1T
Yes you have to ask them.they will be doing their part by terminating their part...you have to do and start from there.
JD
Re: WIC-1T
That all depends which device you want to connect with. Like, if you want to connect with a Radio Modem, you probably want V.35 DTE. For a DXX connection, many vendors use RS232. Consult with your Service Provider or the Equipment manual.
247
