Community Member
WIC 2T not detected
Hi All,
Well I am in a pretty wierd situation. I have quite many routers in my lab and a new addition of 2621XM is the point of problem. It cann't detect WIC 2T cards. I tried to install cards in 2 of its slots but no vail. In those same slots ISDN card got detected and The WIC 2T cards are being detected by other routers i.e. 2610, 2611 etc.
This problematic router 2621XM is currently with 12.4(7), 128 MB Ram, 32 MB Flash. Please give some nice tips regarding this.
On startup this is the message about WIC slot.
Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate"
Thanks in advance.
Re: WIC 2T not detected
Free the router from other slots and try to install it on a another slot, if the problem still exist so i guess it's IOS issue.
Let me know if that gone work.
Please rate helpful posts.
Best Regards,
Mounir Mohamed
Community Member
No changing slot doesn't work. Even I inserted WIC 2T in a separate NM-1FE2W, That NM is detected but all of its ports including WIC2T and FE are not detected. "Show diag" states Port adapter as disabled
Silver
Which image are you using?
Please post sh diag and sh c2600
Are you able to see the cards and the interfaces on the router when inserted.
Post the sh versiona and sh diag
Narayan
Community Member
Hi all,
with some consultancy over cisco site I've replaced 12.4 with 12.3 version. But still its not working.
plz find the attached files containing output of
show diag
show c2600
show version
and
Reload
Hope this will help you guys identify whats actually the cause of problem.
thanks and regards,
Abid Hussain
224
