WIC 2T Problems
Dear all ,
Currently i have cisco 1841 router as connected 2 Mbps internet connection in wic 2t serial0 one port.
Last week i bought new 2 Mbps internet line and connected to free wic 2t serial1 port .
But the link was showing down.Again i connected to wic 2t serial0 port,change the configuration, same error continues.
But i installed new wic 2t card ,the new link was working fine.
What is the problem,old wic 2t card is working fine with old 2Mbps connection,new 2 Mbps connection only creating problem.
Re: WIC 2T Problems
Can you post the output of following commands ?
show run / show controller / show diag
do post out the outputs with both the new and old card and with old connection running up and the new connection showing down..
regds
Re: WIC 2T Problems
Which make of modem you are using for new 2 mbps link?? & also which make of modem you are using for old 2mbps link?? Please let me know.
Prasad
Re: WIC 2T Problems
Dear sir ,
Both are tellabs 8110 mnnl modem
152
