wic 2t
i just happened to get a 2600xm router with a WIC-2t module in it
I wanted to use this router for my home lab so that i can connect the 2600xm router to another router which has WIC-1t as a module (db60 female)
which cable am i supposed to
use so that i can connect the 2 routers back to back
Please help
i would apreciate any help
Hall of Fame Super Gold
Re: wic 2t
One DCE cable, and one DTE. type (rs-232, V.35 doesn't matter as long it matches). Once upon a time, somebody was making direct connection cable.
Re: wic 2t
Not sure why the low rating given to my post that is 100% correct and factual.
If that is your attitude in this professional forum, good luck finding help.
Re: wic 2t
I am sorry about that but it is my mistake as i accidently did that
Is there anyway i can correct it
Re: wic 2t
Understand, and is no problem. You can always rate in fairness any post of mine or others.
252
