05-06-2009 08:24 PM - edited 03-04-2019 04:40 AM
Pros,
I need to add extra L3 ethernet port to the 1760 router.please tell me the above model WIC-4ESW-4-Port 10/100 Fast Ethernet Switch WIC is the correct selection for the 1760 router or we have to go for the
WIC-1ENET-One-port 10BASE-T Ethernet interface. Later one is 10Mbps not 100Mbps.
Please let me know asps.
swami
05-06-2009 08:53 PM
HWIC-4ESW is a Layer 2 switch only. If you need a Layer 3 module, it'll have to be either a HWIC-1FE, HWIC-1GE-SFP or the NME-16ESW series.
05-07-2009 07:49 PM
Hi Swami,
WIC-4ESW is a layer 2 card. You can't assign IP Addresses directly on the physical interface. however SVIs can be uesd if you want to terminate a WAN link.
WIC-1ENET is a Layer 3 module. You can assign ip address on the physical interface. Hoever its a 10mbps interface. If you are looking for layer 3 interface and only one interface is required you can go wit this card.
Loe, Swami is having 1760 router which does not support HWIC modules. I guess you missed the router platform.
-> Sushil
