07-07-2006 03:10 AM - edited 03-03-2019 01:15 PM
Hi I recently plugged in a VWIC-1MFT-G703 into my 2600 running 12.2(1). I keep getting the above error message plus when I run show diag I get the following
Slot 0:
C2620 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.2 Board revision B0
Serial number 3992947983 Part number 73-2843-07
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 94 01 02 ED FF 8D 0F 49 0B 1B 07 00 00 00 00
0x30: 58 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00
WIC Slot 0:
Unknown WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 34907777 Part number 800-06722-03
Connector type PCI
0x20: 01 2F 01 00 02 14 A6 81 50 1A 42 03 00 00 00 00
0x30: 58 00 00 00 06 04 21 00 FF FF FF FF FF FF FF FF
Any ideas what I am doing wrong here.
Thanks ahead.
07-07-2006 03:22 AM
I think that VWIC is not supported on the 23600 series, but I cannot check that because I am having some problem accessing the web site at the moment.
Kevin Dorrell
Luxembourg
07-07-2006 03:41 AM
Hi Kevin,
I'm pretty sure it is supported by the 2600 because the installation manual that came with the card stated that it works with the 2600,3600 and 3700.
07-07-2006 03:59 AM
Please paste the show version from your router. let me know if you are using this module in onboard WIC slot or NM.
HTH,
-amit singh
07-09-2006 06:49 PM
Hi amit,
It's slotted in Slot w0 as required by the manual which on the 2600 is at the rightmost upper slot.Show diag states WIC slot 0 as having unknown WAN daughter card. I am assuming WIC slot 0 = w0 so I am guessing it is in the right slot. Will upload the show version asap as I'm not in the office.
Thanks matey.
07-09-2006 07:46 PM
update your IOS ?
