11-07-2006 03:16 AM - edited 03-03-2019 02:36 PM
Would a serial WIC currently installed in 1720 router be compatible with a 2620?
J Mac
11-07-2006 03:32 AM
Hi Mac ,
can you tell me what type card (serial) is in 1720 router. You can see model using sh diag in 1720 router.
If it is 1-Port DSU/CSU T1 , then it supports in 2600 series routers.
satish
11-07-2006 03:47 AM
Here is the sh diag
Slot 0:
C1720 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.1
PCB Serial Number : JAD0606009D
Part Number : 73-3201-06
Board Revision : A0
Fab Version : 04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 B2 41 06 01 C1 8B 4A 41 44 30 36 30
0x10: 36 30 30 39 44 82 49 0C 81 06 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Serial 1T WAN daughter card
Hardware revision 1.0 Board revision J0
Serial number 0025662715 Part number 800-01514-01
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 02 01 00 01 87 94 FB 50 05 EA 01 00 00 00 00
0x30: 98 00 00 00 01 07 26 01 FF FF FF FF FF FF FF FF
11-07-2006 04:18 AM
You have WIC-IT installed on your router. It will be supported on 2600 router. One thing you have to check if 2600's WIC slots are already full. If the slots are full then you might have to buy another network module to fit in this WIC card. 2600 routers are already EOS and EOL.
HTH,
-amit singh
11-07-2006 03:37 AM
Hi John,
The serial Wics are generally supported across the platforms but amy sometime require an IOS upgrade to support them.
See the following link to check whether the modules are supported on your platform
http://www.cisco.com/en/US/products/hw/modules/ps3129/prod_module_series_home.html
HTH, rate if it does
Narayan
11-07-2006 06:17 AM
The only wic compatibility issue that I am currently aware of is you can not install a Version 1 WIC on the 3800 Series router. The 3800 Series require a Version 2
