WIC1-SHDSL Card
Hi All,
Having received some great help on this forum, I have successfully installed a WIC1-ADSL card in my 2651XM router and
am now thinking of getting a WIC1-SHDSL for it. The version of IOS I have on the router is:
Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(2)T.
My question is whether the version of IOS on the router is at the correct level for it and if there's anything else that I need to bear in mind in the running of one, like memory and the like?
Thanks in advance.
Pat
1 REPLY
Hall of Fame Super Silver
Re: WIC1-SHDSL Card
Hello Pat,
according to SW advisor tool
a 2651XM with the WIC SHDSL
is an accepted HW setup with minimum IOS version:
12.3(26)
c2600-adventerprisek9-mz.123-26
you should be fine
Hope to help
Giuseppe
97
