Wierd EIGRP delay
I'm trying to work out why a route is showing a particular delay value in the Eigrp topology table.
Network is router A connected to router B.
Router A learns of route 10.73.0.0/16 via BGP which is distributed into Eigrp with a delay value of 10000. Sh ip eigrp top 10.73.0.0/16 shows delay as 100000. This is fine.
Router A is connected to router B via fast ethernet 0/0. Fastethernet 0/0 on router A has a delay value manually assigned of 1000.
A sh ip eigrp topology 10.73.0.0/16 on router B shows the delay as 100010. I would expect to see 110000.
Can anyone explain please.
Re: Wierd EIGRP delay
For the delay calculation on Router B, it is not the delay value configured on fa0/0 on router A that is relevant but the one on fa0/0 on routerB.
Can you provide a "show int fa0/0" from routerB.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
There is no delay value manually configured on f0/0 on router b, it is a 100mb FE interface.
Lee
I've added "delay 1000" to f0/0 on router b, the delay in the output of the eigrp topology still shows delay as 100010 microseconds.
Lee
138
