Community Member
will cisco 2800 support pppoa for dsl
am using a dsl connection from etisalt(servise provider at uae)for getting connected to the internet via dsl i need pppoa support on the router.
1 REPLY
Silver
Re: will cisco 2800 support pppoa for dsl
Come on man spell the provider correctly :-)
If you use the WIC-1ADSL you should be fine. I have tested that with the 1841 and 1721 routers. Since it is also supported on the 2800 series you should be ok.
118
