Community Member
Will FX/TX, OC3 and Serial Adapters fit in a 7201 Chassis?
I want to setup a 7201 as a WAN router and want to see if the FX/TX, OC-3 and/or serial adapters will fit in it? Will it?
1 REPLY
Hall of Fame Super Silver
Re: Will FX/TX, OC3 and Serial Adapters fit in a 7201 Chassis?
Hello Matthew,
if I recall correctly you have only one PA slot, but you can use WAN PA on it as well.
see
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/7201_install_config/11364ov.html
Hope to help
Giuseppe
107
