06-05-2007 04:12 AM - edited 03-03-2019 05:18 PM
Hi All,
I need to apply a QoS policy-map outgoing on a frame-relay subinterface on a Cisco 3845 router.
I can either do this via a frame-relay map class and set the service-policy command within the frame-relay map-class or I can apply the policy map to the frame-relay subinterface directly using the service-policy output command.
My question is, which method is better or doesn't it matter?
Andrew Morris
Solved! Go to Solution.
06-05-2007 05:04 AM
No, since you are not using FRTS (you are not shaping), then go ahead and configure the service-policy under the sub-interface, no meaning for configuring it under the FRTS then.
HTH,
Mohammed Mahmoud.
06-05-2007 04:34 AM
Applying the service-policy under the FRTS is recommended because in this manner the queing is done to the shaped traffic while being shaped rather than beeing FIFO ,but unfortunately i have a bad history of it not working unless configured under the subinterface.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
06-05-2007 04:58 AM
Hi There,
Thanks for the response but I am not shaping any traffic.
So does it matter how I apply this then?
Andrew Morris
06-05-2007 05:04 AM
HTH,
Mohammed Mahmoud.
06-05-2007 05:30 AM
GREAT!
Thanks very much.
