Webcast-Catalyst9k
mx
Wireless portion of C3250?
HI. Im not sure if this is the right forum or not, but Ill try. I need to configure a C3250 Router which has wireless built into it. It has the RPTNC connectors out back for the antennas. When I console in, there doesnt seem to be any reference to the wireless section! I can do the router portion just fine. What am I missing? thanks!
bob
1 REPLY
Silver
Re: Wireless portion of C3250?
C3250 have RPTNC connectors, so you have to use a connector so that you can connect coaxial cable with C3250.
As far as antennas go, as per FCC ruling we only allow certified antennas. So these Omni antennas have to be certified first before use.
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/release/notes/rn32mrxf.html
245
