06-04-2014 05:47 AM - edited 03-04-2019 11:05 PM
I'm trying to setup a 1131 AP with three different ssids corresponding to three separate vlans. I feel I'm close to completing this but I can't seem to get all three online at the same time. ssid MickeyMouse seems to always be active and functioning properly. But when I issue the command mbssid guest-mode, that ssid becomes active and the 3rd doesn't show up. I would like to have MickeyMouse and MinnieMouse active for internal use, and Visitor to be for guests/vendors, thus only able to get out to the internet. How can I get all three ssids operational? Then I'll just need to add them to broadcast out on the other radio also. Here is my current (edited) config. Thanks for any assistance
version 12.4
no service pad
service password-encryption
hostname HOME-AP-01
enable secret 5 $1$C3Dr$CG4zHGcd/67zBATjOPygh0
no aaa new-model
dot11 ssid MickeyMouse
vlan 200
authentication open
authentication key-management wpa version 2
wpa-psk ascii 7 0805434008150133070807
dot11 ssid MinnieMouse
vlan 220
authentication open
mbssid guest-mode
wpa-psk ascii 7 15360A05172F32003D303E
dot11 ssid Visitor
vlan 222
authentication open
mbssid guest-mode
wpa-psk ascii 7 063C06316F410D1C544343595B
power inline negotiation prestandard source
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 200 mode ciphers aes-ccm
encryption vlan 220 mode ciphers aes-ccm
encryption vlan 222 mode ciphers aes-ccm
ssid MickeyMouse
ssid MinnieMouse
ssid Visitor
station-role root
interface Dot11Radio0.200
encapsulation dot1Q 200 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.220
encapsulation dot1Q 220
no ip route-cache
interface Dot11Radio0.222
encapsulation dot1Q 222
no ip route-cache
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.200
no ip route-cache
bridge-group 1
interface FastEthernet0.220
no ip route-cache
interface FastEthernet0.222
no ip route-cache
interface BVI1
description LAN interface
ip address 192.168.200.12 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
06-05-2014 02:23 AM
06-05-2014 03:42 AM
check the step by step guide for configuring multiple SSID in autonomous AP
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-3_7_JA/configuration/guide/i1237sc/s37ssid.html
06-05-2014 05:12 AM
Thanks for the replies. All my work has been through the cli, but I went into the gui to confirm things like in your link, and when I go under Security->SSID Manager, there are no SSIDs listed. Not even the < NEW > is listed.
